I can't seem to turn up an authoritative answer for this on google,
I can’t seem to turn up an authoritative answer for this on google, is FastSPI_LED2 (RC3?) supported on the Teensy2++ (AT90USB1286) chip? I figured the T2 (non++ edition) is only supported because it’s the same 32U4 found on the Leonardo. How big of an effort is it to add support for a new CPU? I suspect it’s a bit beyond my capabilities :-/
It should be supported on the teensy2++ - some folks have used it, I don’t have a testing rig set up with one at the moment. There were some bumps with it, but I believe I’ve fixed the ones that were reported to me.
Daniel, I owe you so big… sometimes you make my life too easy with what I’m trying to build. Shoulders of Giants and all that. I’ll have a T2++ here shortly and I’ll confirm it’s working with RC3 and post back. Keep up the good work.
Yeah, teensy 3.0 works well too!
