I could use chilipeppr with grbl 2 days ago,
I could use chilipeppr with grbl 2 days ago, but now I can only jog and I can’t run files. Did something change in the last 2 days?
OK. Now it is working. That gcode module was broken and not responding. Reloading the page again fixed it.
I’m guessing you were paused?
I think the javascript crashed. I did get it going eventually.
I had these problems again. It took me less than 15 minutes to get it going this time.
Can you better describe what problems?
@jlauer ​ it might possibly be related to the grbl widget. I think switching to a different one and then switching back helped to fix it. Reloading the page does not seem to reliably fix it. The drop down on the gcode widget is empty when there are problems.
Just wondering if there are any further discoveries to help you get to the bottom of where your issues may have come from?
@jlauer not really. I think someone updated the code for interfacing with the grbl on April 29th, but I have no idea what that change was.
