I decided to build my own printer. Will use core xy cbot from open builds as its seems to be very scalable. My question would be
Can the Nema 17 handle 16" in the xy?
Is the rumba board the best option out there?
I appreciate any experts out there and your recommendations
@Mark_Moissette_ckaos , every RUMBA board I’ve ever run across has been a huge pile of buggy shit. I don’t know what’s going wrong with their production, but there’s always a certain portion of the board that’s just borked.
@Ariel_Yahni_UniKpty , it may take about more configuration to run a printrboard due to the AT90USB processor; also some of the source code for marlin may not have the right pins configured, and you may have to fool around with pins.h
They don’t really use the main branch for developing, 32 commits in the last month. . The 0.92 branch is where all the development is going on and has many commits. I know a few people that would like to debate that but I’ll just let it go. I’ll go with Ryan and say the duet or RADDS with RRF will be the next wave to jump on.
If you must use Marlin, make sure you have the watchdog enabled… It’s very dangerous to run with that disabled. It got turned commented out a few years ago because an Arduino IDE version was causing trouble with it, and never got turned back on in the main branches when the IDE problem was fixed. It’s off by default in all the online configurators and almost every fork. This is completely unacceptable with software PWM, because it can stick your heaters on 100% power of the firmware freezes. Only Ultimaker forks and very fresh downloads from the main fork consistently have it on. Seriously, go check now if you have it enabled, it’s embarrassingly unsafe to have no watchdog with software heater PWM.
Repetier is much more optimized for performance than Marlin, and has good support and a healthy level of activity. My only real gripe with it is that there’s no good delta auto-calibration option. But it beats the pants off Marlin in terms of max speeds, motion stuttering, etc. (Almost as good as Sailfish, heh.) I know a lot of people who do initial delta calibration in Marlin and then plug the auto-cal values into Repetier so their printer will run fast enough. That says something.
As of right now, the dc42 fork of RRF is seeming like a winner overall. Good attention to safety, 32bit processor, works on Due+RADDS and Duet, excellent delta auto-cal.
@Ryan_Carlyle , rofl – considering your comment, you should check out the Marlin commit made 20 days ago. Watchdog was recently reenabled as a default.
