I designed a pair of fan shrouds for my Felix 3.0 to improve the
I designed a pair of fan shrouds for my Felix 3.0 to improve the airflow over the workpiece.
https://www.youmagine.com/designs/felix-3-0-dual-fan-shoud
I feel this may produce too much resistance and burn out your fan. Have a look at a squirrel cage fan such as a Nidec Gamma. They should offer more air flow through a smaller opening that you could then direct a bit easier.
Blower fans give much better airflow when ducted.
“You might leave the supports as flow directors. I removed mine to reduce the backpressure.”
