I discovered a weird bug in laser web 3 where would i repoty it or get an explanation as to why its doing it?
+Peter van der Walt
+Peter van der Walt it won’t cut circles that are in .DXF files in the correct location it moves them all to the origin when a gcode is generated
@Derek_Schuetz please post you issue here https://github.com/openhardwarecoza/LaserWeb3. Include your file. I can confirm your finding
I’m generating .dxf in fushion 360 can you do poly lines that way? +Peter van der Walt
just tried an addon same issue
+Peter van der Walt all posted with several examples on the control panel is the one i tried to use poly line adon
No rush I already left it aside before I go insane
+Peter van der Walt that is really weird I even opened another window and it did it also
