I don't suppose anyone has heard from Roy Cortes from Panucatt Devices recently?
I don’t suppose anyone has heard from @Roy_Cortes from @Panucatt Devices recently? Been trying to get hold of him with regards to my X5 Mini being not quite right and locking up while probing the bed.
I’ve pretty much exhausted all avenues to fix it myself so it’s got to be the board, before you say anything, if you can think of it I’ve either replaced the part or tested with known good and tried multiple firmware versions. I’m now down to thinking the memory is faulty on the ARM chip, other than probing for calibration, it works mostly fine. It will complete calibration if I pull the card, redo the config, re-insert the card. Just as an example of what I’ve done, it’s not the SD card, probe, firmware endstops, stepper drivers or anything else that attaches to the board as I’ve tried pretty much everything that does, that leaves me with the board itself.
I’ve tried multiple avenues to get hold of Roy or anyone from Panucatt but with pretty much no response apart from my orginal e-mail, which I know is strange as I know communication is usually on point.
You’re not the first to complain about never hearing back from Panucatt for support. I still haven’t seen the uSD card I bought with my board.
@Jeff_DeMaagd - seems this post helped, I’ve been contacted and the board is being replaced, although I’ll believe it when I have it in my hands.
