I feel a bit silly asking this, but do any of you have tips on how to knot and (re)tighten fishing lines for your machines that use them (in my case 3DR reprap). So far I haven’t found a non anoying, non tricky way to do it.
@Mike_Miller you might have something for this ?
Thanks in advance !
I’ve found this site to be very handy. I use the bowline for hitching and the zeppelin bend for joining ends.
I wrap em around a zip tie and pull it tight to tension. I’d post a picture, but I’m away from home.
@Matthew_Satterlee very nice site and tip, that will come in handy ! Thanks !
@Mike_Miller thanks ! is that the same method described by richrap in the 3dr build posts ?
It is, but I wrap em a while lot more times than he suggests.
@Mike_Miller ok,thanks, I might have not done it right the first times then, will give that trick another go:)
