I got a problem with my delta, where it does not seem to home correctly.
The problem is if it got the hotend in a radius about 100mm from center, and I press home. It then starts to move all towers up, bumps one switch, lets the two remaining towers move a bit further, stops them, retract from the endstop that was triggered synchronized with all axis, bumps the endstop again, and stops the homing. It it just done homing, with only one tower homed, and the remaining two 80-100mm from the endstop, but believes all o them has been homed, because afterwards it just goes full speed into the build plate.
What can cause this? I have checked the endstops for noise with my oscilloscope, and found nothing that should trigger the remaining two endstops to believe they have been pressed. And just to try, I tried to also add the debounce to them.
Looks like it was the problem with the firmware version, right after posting I rebemmered I was on an edge build (Build version: edge-b77d053, Build date: Aug 1 2016 04:05:46, MCU: LPC1768, System Clock: 100MHz) so I just switched to Build version: master-27197b7, Build date: Jul 4 2016 04:10:42, MCU: LPC1768, System Clock: 100MHz and finished the G32 successfully with that. So it works fine with the master version.
You don’t want to be using master, you should always use edge. Please try again with a fresh firmware off github and a fresh config file ( which you edit to add your settings again )
I have seen this problem too, with a firmware update some time ago, but I didn’t have time to do anything about it at the time and forgot it again. I have updated the firmware again since that and the problem seems to have vanished. Please tell us, if a fresh firmware solves the problem for you, so we can know if it is still an issue.
max_travel were in, instead of following @Arthur_Wolf 's advise of doing a fresh config, I started out by just trying the firmware change to see what happened, and without changing the config, it went from not working, to working without a problem.
