I had a vendor reach out to me with a good sized lot of NEMA 17 motors. Specifically these two motors:
Minebea/NMBTechnologies 17PM-K077BP01CN
Minebea/NMBTechnologies 17PM-K374BN01CN
Are these any good for building 3D printers?
Need to find the spec sheets. Do the leg work, and determine the application, what type of 3d printer, what speed.
the 374 got an odd shaft for the pulleys , its square for god shakes ,but least you get four flats for the grub screw in the circular ID of the pulley.
What’s the holding torque, rated current, inductance, and resistance?
Link to spec sheets: http://imgur.com/a/JZkfC
@Ryan_Carlyle Link to spec sheets: https://i.imgur.com/sASHtg1.png
https://i.imgur.com/dfl4NRM.png
Those are very “slow” motors – high inductance, high resistance, will have lots of back-emf. They won’t work for microstepping unless you have a very high voltage supply (maybe even higher than 24v).
Wow I haven’t seen those numbers like that in a step motor. Either very bad or useless for 12V.
They would be good if you want low-speed motion without a lot of power draw, like a security camera or something.
