I had problem run mach 3 for ox cnc and cbeam.
I had problem run mach 3 for ox cnc and cbeam. i set motor turning for X, Y, Z axis is step 200 velocity 2000 acce 2000 and pulse dir 0. for testing, i move x or y 100mm, 106,5mm in turn for actual. i changed bob mach 3 to grbl bob, which is ok overally. ANY OTHER SUGGESTION FOR FURTHER USING MACH 3 or any sharing experience when using mach 3 for me to learn more.
Thanks in advance.
Grbl is much better
That’s what you get for running Mach. I wouldn’t let Windows switch a light bulb.
bác Vinh có bản mach 3 nào việt hoá cho em xin với
No cnc software works with wrong configuration. Incorrect movement is never due to windows or mach 3. It’s most likely either configuration or hardware problems.
YouTube Motor Setup.
Under settings tab (alt+5), there is a button, “set steps per unit”. I can find a tutorial video when I get home
