I had to source a 300x300 heatpad for my new bot and all the ones I found in the states were $40-50 plus shipping so I hit up a few suppliers on Aliepress and these guys came through with a 300x300 270W pad for $38 including shipping. I told them they should list some common sizes and so they did. The pad I have is good quality (as far as I can tell), these folk are the people that supply QU-BD with their heat pads.
http://www.aliexpress.com/store/product/200x200mm-24v-200w-Silicone-Heating-Pad-Heater-With-100k-thermistor-For-3D-Printer-Bed/709519_1354863110.html
@Thomas_Sanladerer What’s your thoughts on having a section for this sort of stuff? I know it might encourage spammy marketing things but when I find a great deal, I like to tell people.
I also bought one from there. 150x150, thermistor, 300mm leads and shipping for $28. Qu wanted $48
How do you use these silicone heaters ? Glue on glass ?
@Shachar_Weis they have a 3m adhesive backing and you could adhere it directly to glass but I’d recommend a thin sheet of Aluminium to spread the heat more evenly and allow you to remove the glass.
Nice find. They also have circular pads, useful for delta printers.
Hm, links like these would helpful for pretty much everyone building a bot. As long as it’s very clear what is ok to post and what is not, i’d say go for it!
@ThantiK ?
I recently built a 12"x 12" build area I ended up using 2 x 11 1/2" lengths and 2 x 10" lengths of 14ga nichrome connected with but ends and 12ga copper i stripped insulated with kapton. I hook it directly to the 12v 750watt server power supply and max at 125 c heat time is under 30 minutes my wire element is kapton taped to the bottom of my 12" x 12" x 1/4" aluminum plate and 3mm glass square is held on top with a few bulldog clips.
i made some MK2a heated bed with 328328mm size, printing size 300300mm, suggest use 24v.
