I have a chained led strip and I am trying to get 4 overlapping flames so it does not look like the start and stop at the same time. What is the best way to achieve this? here is my q on s.e.: https://arduino.stackexchange.com/questions/45439/multiple-random-fire2012-sequence-in-same-strip
Create 4 independent time registers. Seed each with mills()+random offset mills. Each time currwnt time exceed time register do update start new pattern then reset register with new random
In your case the better way to make a 15x4 matrix. A little bit modify code of Fire 2012 Mark Kriegsman, and you get 4 independent fire. if interesting i can show code 3-4 hours latter
@Ivan_Fominskiy that would be great. I am new to FastLED and this is my first arduino project
thanks @Ivan_Fominskiy looks perfect!
great effect!!!.. would love a share on your method.
@Steve_Borgelt Great looking setup you have going there now! Share on http://gist.github.com if you can.
