i have a i3 cone by ctc, with the mk8 extruder and hot end,
i have a i3 cone by ctc, with the mk8 extruder and hot end, works perfect. today i make 2 parts to adapt it to work with a boden tube, as seen in the pictures, after doing a test print, it looks to be under extruding really bad, i havent changed any settings yet as i though adding a boden between the extruder and hot end woundnt make much difference if any, if its already primed, what can people recommend i do to try and get it to work
note checked the feed rate, when i tell to extrude 50mm i get 50mm
Partial clog?
ه ق ف عق ىو عق اب
