I have a K40 laser, which stopped burning half way through a job. The cnc part of the machine is working perfect, but the tube isn’t firing. I replaced the tube, but still nothing. Has anyone any idea what could be the fault. Any help would be greatly appreciated.
Thanks… Stevie
The circuit goes as follows as I understand it
PSU Supplies HV to tube
WHEN
the laser switch makes contact (is depressed)
AND
the power Pot is turned to a value (usually 4 ma or over) that causes the tube to lase.
Therefore
either PSU is not supply HV
OR
Laser switch is not making contact
OR
Pot is faulty
given your symptoms ie: stopped in middle of a job I’m betting on the PSU being FUBAR
You can test the laser switch with an ohm meter and the unit off
you can also test the pot with an ohm meter and the unit off
DO NOT TRY to test the HV unless you know what your doing - the consequences could be lethal
Hope that helps
Thanks greg
Do you have any other safety switches, water flow, lid switch ect… If they went bad and opened your circuit that will stop your tube from firing also.
No I don’t have any other safety switches Rick.
