I have a k40. I recently replaced the pot with a 5k pot and my meter due to the pot being sporadic and the meter would just keep hitting max.
Now the most I see in the meter via the test button is 8ma. Tube otw out?
Thanks
Thanks
Likely a worn out tube.
Exactly my thoughts
Pretty sure the stock Pot is a 1k
@Alex_Krause I have seen both 1K and 5K used. I have 5K in mine :).
@Alex_Krause no idea I seen ppl replacing them with 5k for better control that’s why I did it
@Chris_Menchions the resistance doesn’t provide better control its that pot type that does that. The pot we use as a replacement is a multi-turn pot that has better granularity (more turns for a given resistance). A 5K was all that was available in that type pot.
Ok
Update: @donkjr and I have come to the conclusion that it has to be the readout from the power supply. The meter works and the machine cuts and engraves. That same psu has interlock issues where the test button bypasses the interlock. Will be getting a new PSU soon hopfully that fixes it.
