I have a printerbot simple metal with heated bed. This printer has a auto level probe. How can I set my Z offset height using commands in terminal to get the exact -.2 .-4 height that I need? I did try Mattercontorl method to set Z offset but its not exact and need to get lower on my Z axis. Can I use these commands? http://help.printrbot.com/Guide/2.+Setting+Up+Your+Auto-Leveling+Probe+and+Your+First+Print/107
http://www.mattercontrol.com/
Anyone using Mattercontrol with a printrbot simple metal?
The Printrbot guide is what you’re looking for. Just do it!
So can open terminal in Mattercontrol and use the same commands such as in Cura to set up Z axis offset? Thanks Thomas
Yes.
Isn’t Z offset saved to the PB firmware? It should persist between software, if I understand the operation correctly.
@Tom_Nardi that’s what the M500 command does. Set it once and it stays with the printer, independently of the host software.
Well so you can’t use 2 different software packages to print on the same computer? If it writes the Z offset to the printer then if you fire up another slicer it will be off. Very confusing
@John_Car there’s mo need to have different offsets for different slicers. They all assume a perfectly adjusted printer unless you tell them otherwise.
Understand but when I installed MatterControl and tried to print a test cube the Z offset was to high and the print cube turned out really bad. I wonder if the automation level function on Mattercontrol screwed up the settings. I am going to try to print a test cube using Cura to see if that is the case.
Thomas you should test this and make a video on the subject. Load up Mattercontrol and Cura and do a proper video explaining how to setup both on the same computer. Sure you will get a lot of views on the subject.
@Thomas_Sanladerer I think i found the issue. The startup Gcode for mattercontrol is only
G28 X0 Y0
G29
Which I think resets the offset from the one that is set on the printers board.
Cura startup Gcode is
G21 ;metric values
G90 ;absolute positioning
M82 ;set extruder to absolute mode
M107 ;start with the fan off
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstops
G1 Z15.0 F{travel_speed} ;move the platform down 15mm
G92 E0 ;zero the extruded length
G1 F200 E3 ;extrude 3mm of feed stock
G92 E0 ;zero the extruded length again
G1 F{travel_speed}
;Put printing message on LCD screen
M117 Printing…
Yep that was the issue I added the same Gcode to Mattercontrol startup and perfect print.
