I have a Printrbot Simple Pro with the heated bed option.
I have a Printrbot Simple Pro with the heated bed option. The current build plate has what I think is PEI on it. I need to change it as it has become very scarred from use. What is the best way to remove it, and is there anything I should be aware of when putting down the PEI?
I believe some companies bake their pei sheets to remove moisture from them, to prevent bubbling.
Removal is a manual effort. Scraping and peeling. Solvents like goo-gone or limonene can help.
Here’s the Prusa Research instructions for removing a PEI sheet from their build plates: http://manual.prusa3d.com/Guide/Replacing+the+PEI+sheet/133
Thanks for the info
