I have a problem setting up my hotbed in that the hotbed warms up
I have a problem setting up my hotbed in that the hotbed warms up nicely but the temperature is not registering at all, I have tried using other connections resetting what needs to be reset, but nothing seems to happen. i get reading from the hotend but not the bed, I have tested the thermister using a multimeter and heating the Bed and have seen the resistance change as the temperature rises. the hotend on T0 returns two readings but reports both as T in simplify3D, The same happens on Pronterface. The lights on the board show normal. I have checked the troubleshooting guide and followed the guide for this problem. added to this when the T1 Connection is live and T0 is not we get inf. when T0 is connected and T1 is not, two readings appear, does anyone have any helpful suggestions?
can we see the result of the M105 command, as well as your config file on http://pastebin.com ? Thanks.
I Have sent the config file to http://pastebin.com it includes the result of
sending the M105 instruction. I signed up under the username gismogajet
Regards
You need to give us the exact link to your config file, that’s how pastebin is used.
The link is https://pastebin.com/NCAE3rNA at least thats the URL at the
top of the page, sorry I failed to send this before but I am not used to
the way this works yet!
Regards
James
Hey.
It says “This is a private paste. If you created this paste, please login to view it.”
You need to just go to http://pastebin.com, paste your config, submit, and give the resulting link.
I will check and re-paste but I thought I had set it for public.
I have re-pasted the config the link is: config prusa i3 - Pastebin.com
Regards
James
" temperature_control.bed.thermister " is incorrect, it should be “thermistor”.
More in general, when editing config, you need to do what the documentation says : start from the example config file, and edit only what is STRICTLY necessary to get things to work, and not anything more. Once everything works, you can save the working file, and play with the formatting, but not before.
Sometimes men do stupid things and I am no exception, Thank you for your
help it is appreciated.
I am hoping to build my own printer at a later date and understanding
smoothieboard and smoothieware is key to that end.
I hope to use the Laser module on that printer.
My intention now is to put a copy of my config file on my computer and do
what you suggest replace it with the original example and start again not
because I have to but because I want to.
