I have a reprap prusa i3 and it keeps clogging, what should i Do?
The first step to determine a solution to a clogging problem is to provide additional information. What type and/or brand of filament are you using? Do you get clogs with other brands/types? At what temperature are you running the hot end? Are you able to clear the clog and if so, how are you accomplishing that? Do you know what your retractions settings are? So many questions, so few answers.
And is that an original Prusa i3?
I have an i2 with same problem, mostly when running ABS. Ended up overheating and deforming the wades extruder and the hot end.
I’ve put in an all metal hotend and extruder, and added another cooling fan.
