I have a strange problem. I bought a couple of strips of what was advertised as WS2811 strips but I can’t make it work.
A simple code which should light each pixel red in 1-second intervals produces an effect of 3 blue pixels. (code: https://pastebin.com/7mu0p2UZ)
Here’s a video of that effect:
The strip chips have no markings on them - just a standard looking 8 pin chip for every 3 LEDs. I tried setting other chips in the code in case the seller didn’t know what he was selling/sent the wrong strips library but none of that helped.
@Jaroslaw_Pendowski Have you tried changing your RGB order line 9? Still doesn’t fix your counting errors though. Are these 3 or 4 wire leds? Difficult to see in the video.
@Stefin_T@Tom_Schubert GRB helped with the color but it stills lights up 3 LEDs at a time (both with WS2811 and WS2812B).
Now when I think about it - since there are 3 LEDs per segment (+4 resistors, 2 capacitors), maybe that’s a hint of what is going on/what chip is it.
I guess there’s always a chance that the chip addresses all 3 LEDs not each individual one, even if it was advertised as one.
