I have an SVG file that I seem to be having issues with. I am runniny Turnkey Tyrannys ramps 1.4 setup, and was hoping someone on here who is also running this could give the file a try so I can check my Gcode against yours for errors.
Thanks in advance
https://drive.google.com/file/d/0B23r3Hp4r5U7NjJrM1o2dllzYjg/view?usp=sharing
Not sure what Turnkey is etc, however I just grabbed the file & opened in Adobe Illustrator. First thing I notice is that your text has changed font (from the image I see above). I would consider converting the text to outlines/paths for a starter. No idea how G-code works, but could that be the problem?
It is the raster module in the Inkscape plugin that is giving me issues, vectors are OK
@funinthefalls Hope you can sort the issue. I don’t use Inkscape or Turnkey/ramps etc, so have no other suggestions for you.
