I have and idea.
I have and idea. I’m submitting it here to you capable folks because I do not feel that I have the resources to take advantage of it.
It’s an idea to build a simpler rotary 4th axis for cnc, with a fraction of the parts.
It works kind of like an automatic tool changer, you would move the carriage to a certain place then the z axis would actually operate the A (rotary) axis position. There would need to be some kind of linkage between the carriage and the A axis.
I’m not sure precisely what that would look like. Maybe a star disk (5 or 6 lobe). The Z would go down to the bottom then have to come back again (several times) if you wanted to do 360deg.
You would need a few more pieces though.
The A axis would need to stay in precisely the position it is placed, for that it needs some sort of brake. I would immediately think a disk brake from a bike would be a good way to go, but there are many ways to skin that cat. There would need to be an actuation for this brake, such as a solenoid or you could use a stepper or servo (giving up the lower complexity). An encoder wouldn’t be a bad idea either.
Then there would be the software.
I will post this over to Smoothieware and CNCWeb communities as well to see if anyone wants to give it a whirl.
http://cdn4.explainthatstuff.com/typical-cam-shapes.png
I’m curious how you see the tool movement being controlled if your Z movement is being used elsewhere. I’ve read about setups that allow you to swap your x or y axis onto your a axis, so you still only have three axes, but one is rotary. That makes some sense to me. I’m struggling to figure out how to cut material when I don’t have independent control over the tool height.
Much like a tool changer once the A axis is in place the carriage can move back over to the work piece…
It’s not a solid linkage.
It could be a simple vertical rod with a bearing at the bottom.
If the A axis rotates around the x axis then the bearing would be oriented along that axis too. …
When you move the assembly (carriage+rod+bearing) to a set position, the bearing interfaces with the cam and you can turn the A axis.
Same as this… just rotate it 90deg and add the brake and cam.
@John_Bump as I comprehend what is being said, like a tool changer things only happen when the head is in a specific position. It seems like what is being suggested is the loss of a bit of Y axis volume to make the A axis function. Instead of 500mm you might give up 5mm or less and to actuate the A axis you would move the head to Y -5 or something similar. That way when the head is to the negative of machine home you are moving the A axis.
Edit: In the comment above when I said X axis I did in fact mean Y Sorry for the confusion…
Thanks to @Kyle_Kerr for helping me see my little error…
@Kyle_Kerr I believe you have the right idea…
The real problem I would see with your idea is all out the extra movement required to adjust the rotary axis. Your CAM software would have to be aware of the way the A axis is actuated because things wouldn’t work as nicely/easily as they do with a powered rotary axis.
I don’t mean to rain on your parade, but, your idea seems like a solution in search of a problem. At least as I comprehend what you are suggesting.
Seems like alot of times you would only need a few moves to get all the way around an object.
4th axis is often really used as 3.5axis…
As in the machine can get everything in a 180 degree manifold, making only 2 moves.
Or maybe you have a shorter bit and need more detail. So you have to move every 60degrees to get around your object.
It wouldn’t truly replace a real 4th axis, but it could save you having to go in and reposition your piece for different operations.
Just when I think I’m making head or tail from cnc machines someone post something that makes no sense to me. I feel like a tree at the end of a runway.
Is what’s being said that when the y axiz moves to for example -5 the steppers engage via a cam to turn the work instead of the gantry thus moving the work like a lathe or turn table would.
And my question what is the saving in tooling to do this seems like at most you’re saving one stepper motor and driver.
The 3.5 axis idea makes a ton of sense. I could use that. A lot of my work is sequential setup for dofferent faces.
@Michael_Scholtz ​ check out the xatc video I posted above…
He uses the cnc movement to turn the tool turntable.
This is essentially the same idea but using that motion for a 4th axis.
Yes, mainly saving 1 stepper and driver. Maybe it’s a better idea for prebuilt cncs that want another axis rather than diy cncs that can add any axis they want :confused:
