I have been asked to fill a 12m by 0.4m area with an LED
I have been asked to fill a 12m by 0.4m area with an LED matrix by a friend. So I have been looking at the Octo DMA library but have just noticed the multi strip additions to FastLED. I am thinking about 24 strips of 720 leds. My question is about what appears to be 2 different systems. I presume OCTOWS2811 uses DMA and that WS2811_PORTD does not, has anybody used these? Is the non DMA’d type much slower than driving a single clockless strip?
Hi Aaron,
what kind of content will the matrix be displaying?
What sort of refresh rate are you hoping to achieve?
Which pixels are you planning to use?
Scrolling text, sprite animations and patterns. Was thinking about WS2812’s hence my questions about the Octo stuff. Have previously run 800 off a single wire with a Teensy 3, which just about managed an acceptable refresh rate. But if the multi output works well I could drive all the strips/LEDs off just 2 Synced Teensy’s. I should really just deconstruct one of my Matrixes and hook it up to do some timings, just hoped someone here may have already tried the code out :slight_smile:
I asked, because I didn’t want to give you a bum steer, if you came back with, “oh great, this video wall will be awesome”.
Have a read of:
https://github.com/FastLED/FastLED/wiki/Parallel-Output
I haven’t tried the OCTO driver yet its sat here looking at me, but looking at the timings on that page 720 LEDs is fine.
SO, 24 strips * 720 LEDS = 17,280 LEDs.
That means your Teensy3.1 will be running 8 lines of 2,160 LEDs in parallel. With my calculations, it would take 7,992us to write 8 lines.
And, 51,780 bytes of space will be needed for your leds[] array.
Thanks Stuart Taylor for the RTFM :slight_smile:
First used FastLED a year ago and have got used to scanning the source code for help due to the limited instructions but now I see the guys have made a massive effort to get the documentation updated!
Hi Jon, I am actually thinking about using 3 Teensy 3.1’s so would only drive 8 strings of 720 off each one and would just need to sync the Teensy’s using a single data line. From what I can see the Octo code requires 6 bytes for each LED only (4320) and FastLED is 1 per LED (5760). So only 10K LED RAM per Teensy.
TBH The bit that worries me is the power, 300w 5v supplies I can get at a good price, but will need 24 of them!
Hi Aaron
I tried all of your example in RGBLEDS, with FastLED 3.1
All of examples have the same error:
Arduino: 1.0.6 (Windows Board: “Arduino Uno”
MatrixExample1:15: error: expected constructor, destructor, or type conversion before ‘<’ token
MatrixExample1:15: error: expected unqualified-id before ‘>’ token
MatrixExample1.ino: In function ‘void setup()’:
MatrixExample1:22: error: ‘leds’ was not declared in this scope
Thanks for help me out.
Hi,
I use v1.0.5.r2 with Teensyduino addon, I couldn’t find 1.0.6 on the Arduino website.
Having said that it seems to be failing with the template aspect of the Matrix class which is standard ‘C’. I would try reinstalling the Arduino software or even upgrading to V1.5.8 as you are using an Arduino board. Sorry I can’t be more help but I don’t have an Uno only a Due which requires 1.5 and above.
Thanks
I’ll try 1.0.5r2
