I have been trying out FastLED on several of little Arduino clones,
I have been trying out FastLED on several of little Arduino clones, including the Attiny85-based Digispark (from Banggood and AliExpress) and so far haven’t found any real show-stoppers and they all have worked so far. I have found one thing that looks like it might be an incorrect definition in the library however.
The FirstLight example is something I wish I had found right away, there is a lot explained in this example and I thank you all for it. HOWEVER: I found it because I was having trouble trying to use this statement:
FastLED.addLeds<LED_TYPE, DATA_PIN, COLOR_ORDER>(leds, NUM_LEDS)
I discovered that if LED_TYPE = NEOPIXEL then COLOR_ORDER should not be passed. OK, but if I use NEOPIXEL (and don’t pass COLOR_ORDER) then red and green are reversed:
leds[whiteLed] = CRGB::Green;
gives red (and vice versa).
If I look at the Adafruit NeoPixel Überguide, I read that NeoPixels are GRB, not RGB and I am using real NeoPixels from Adafruit.
Substituting
FastLED.addLeds<WS2812, DATA_PIN, RGB>(leds, NUM_LEDS)
gives me green when I execute the same statement as above.
Changing to GRB makes the colors turn out correctly.
Am I doing something wrong or is this an oversight in the Library?
Takeaway: Test your strips to make sure you’re using the right color order.
Also: I’m using 3.1 but get this message when I compile:
#warning FastLED version 3.001.001
Is this just the numbering system and I need to get used to it?
The developer has that there intentionally (as documented in github at Unnecessary warning? · Issue #244 · FastLED/FastLED · GitHub) but the pause in the compile annoys me enough that I added this line before my library includes:
#define FASTLED_INTERNAL 1
If you are planning on asking for help, comment it out before submitting your compile errors.
The warning doesn’t pause the compile at all.
As for the neopixel thing - use WS2812 if you want to change the color order - I am changing this in the next version of the library because adafruit has started selling neopixels with other rgb orderings.
(I’m really regretting having added something in place so that NeoPixel default orders to GRB - it’s caused no end of problems for me :slight_smile:
RGB/GRB - sorry if I touched a nerve.
WRT the #warning, my question was not a complaint. I was curious why I installed and am using 3.1 and the compiler gives me #warning FastLED version 3.001.001. If that’s what it’s supposed to be, I’m fine with it. I have no intention of submitting compile errors as there are none. The library is incredible and currently beyond my meager ability to comprehend.
It’s all good - 3.1.1 is the current released version of FastLED3.1 - so that’s ok. (I bump up the minor version number from time to time as changes get made).
