I have been working with auto-leveling and have three questions and one new approach others might be interested in.
Question 1: As shown in the attached video, during probing, the probe seems to move substantially in the XY plane. From what I can tell, it doesn’t affect anything, but I still suspect I am doing something wrong. Thoughts / Suggestions?
Question 2: Am I using the layers correctly? After positioning the spindle to 0,0,0 I zero out G54, then G92, first for X, then Y then Z. Is this proper? If so, I can’t see a purpose for the G92 layer. Perhaps this accounts for my problem in question 1 above?
Question 3: After I get the auto level data, the individual values shown on the display are obscured by the graphic of the actual Z values. Is there a way to easily see those individual values? Is there a way to change those individual values?
New Approach. As I described previously, I am using a fast relay to allow me to probe with 9v. When the probe makes contact, a light on the relay illuminates (which is very handy) and the relay closes to provide the tinyG with its signal. I think it is working well, but I think I still occasionally lost steps, as evidenced by the Z value at 0,0 being significantly off after 400+ test probes. I was also scratching boards (stupidly). To address both problems, I improvised a probe by taking a broken end mill (I have a big supply of those) and attaching the spring from a ball point pen. The bottom of the spring extends a couple mm below the endmill, so even if the probe travels beyond contact, the spring absorbs the excess, no steps are lost and my board isn’t damaged. And if I forget to raise the probe before jogging it, no harm is done. I can’t figure out how to post a pic but will do that separately.
https://youtu.be/4wDMamCQy9g
