I have some components (some pins and a switching Regulator DC to DC 5V)
I have some components (some pins and a switching Regulator DC to DC 5V) to weld on my Smoothiebord, I never weld on a pcb board so what is your opinion:
Soldier it rather than weld it for starters… i think you’re in above your skill level.
Just an FYI if this is your first project… Don’t do it, get a solder practice kit. If you screw up and drip solder on the board you will break the thing.
+Peter van der Walt
Thank you, I really appreciate. I will do it, I have a lot of motherboard and stuff like this, I will try with this first. If i not sucess I will send it to your daughter :). It’s good to be here to can improve skill and vocabulary. Thank you again.
Thank you everybody for your opinion, I WILL DO IT :slight_smile:
dont ‘DO IT’! Just ‘do it.’ if you use all caps and an exclamation point while soldering you need to use a heatsink as well, the extra energy can burn out components on the PCB.
