I have trouble with connecting to pc with USB at first it worked then
I have trouble with connecting to pc with USB at first it worked then it suddenly stop connecting said that I have to manually choose port.
That resulted in that I downgraded to 2.08 everything ok until maybe 2-3 reboots (2 off then power off)
And then suddenly same thing please choose port manually…
Are you connecting from Windows, Mac or Linux? It may be a PC issue with the driver timing out
Mmm, k that may make more sense. I’m only ever using Linux when connecting to the USB
OK IT works now so back to config… :slight_smile:
Could you share how you fixed it? In case others run into the same issue later, it would be greatly appreciated.
Hi i Didn’t fix it I reflash the firmware so the problem will probably come back. I will come back then if I find the solution
