I have two printers in my classroom (Ultimaker Original and Flashforge Creator Pro) two
I have two printers in my classroom (Ultimaker Original and Flashforge Creator Pro) two days ago the Ultimaker started shifting XY during the first layer of the print. I tightened the short belts and cleaned and greased the rails. I tried printing different files…no luck. I did notice that it sort of “zigged” at two places on the platform every time during one print which is why I suspected the belts or rails.
I had a new set of long belts and brought the printer home to work on it this weekend. I tried to print again to see if I could tell where it was having issues again. It is now printing beautifully.
I also have a Flashforge Creator Pro in the classroom which I started using when the Ultimaker went down. For the last day and a half it has been having problems where the filament isn’t adhering to the platform (again it had been working perfectly until a day and a half ago. I have leveled the bed multiple times but no luck.
Now I am wondering if there is some common cause that is messing with both printers in my classroom…maybe something electrical?
I appreciate any ideas.
Did you check if the pulleys are still secured on the UMO? Most common is the pulley on the motor getting lose and causing these kinds of shifts.
@Daid_Braam I have not checked that but will do that today…thanks
pulleys are secured belts are tight…I’m looking at possibility that the short belts need replacing…am getting ready to order replacements…is there anything else I should order that could be responsible for the XY shifting during the print (sometimes during first layer…other times mid-print)…I’m on a time crunch and want to be sure and order all parts I might need.
Thanks
Well, another possible reason could be the electronics overheating, that also causes layer shifts. Are these the Plus variant or the early variant with the noisy fan?
It’s the early noisy fan…I will definitely add the fan to my order…thanks
Also, I assume you oiled the 8mm and 6mm axes already?
Thanks for the tip about overheating causing XY shift…my first clue the fan had issues was when i took off the bottom panel and four heat sinks fell out…I re-glued them and replaced the fan and no more XY shift! Thanks again
