I have upgraded my laser, have Power Supply, Moshe board, gauge ,posimeter?
Make me a reasonable offer!
The garbage is a great place for these. (Well, except the power supply)
Can you post a pic of the power supply?
I will add it as soon asI can figure how!
Posted picture see Lori Martin
Does the Moshi board have the flat cable connectors on it?, if so, how cheap will you let it go? (just want connectors for Smoothie conversion), and finally are you in US (or within mailing range for a reasonable price)
I’ve not found 'middleboards" yet, and would like to avoid cannabalizing my (Gen 2) existing board
Scott
Oh yeah, what’s a posimeter?
Middleman boards are a bout $10 for a set of 3 bare boards, connectors are about 50cents each.l
I have posted a picture of the power supply. It doesn’t even have an hour time on it.
I can send you a picture of the board if you want.
If I can get the source for the middelmanboards from Tony, I won’t have to destroy a usable board. Better to sell to somebody that needs a replacement.
@funinthefalls
Sounds Great! Where can I get some?
@Scott_Marshall https://oshpark.com/shared_projects/3W1BpcNl for the boards.
http://www.digikey.com/product-search/en?KeyWords=A100331-ND&WT.z_header=search_go for the ribbon connector.
The rest of the connections can either be soldered or use pin headers. Hope this helps Scott.
@funinthefalls
Thank You!
