I haven’t seen anything like this yet but has any body thought about moving the head of the laser around to the other side of the X bar? I was just looking at mine and thought if it was possible you could gain about 50mm at the top.
It would mean swapping the head around and re-mounting the second mirror to the other side of the stepper motor but it could be worth it for a 300x320 ish bed.
I don’t think so because at the bottom of the run I have nothing more than a piece of garden hose. I’m pretty sure if this was taken off the actual mechanism with run under the the bottom x support bar.
Someone else was talking about doing it, think it might have been on a web site, but in doing so it fouled the metal casing, so you’d need to mess with the end stop
I tried it a few weeks ago, it didn’t work out. Then I made a new laser mount plate out of aluminum so that the laser is more closer to the carriage at the original side of the carriage also needed to cut aluminum away from the top back side of the gantry and cutting more stuff. I managed to get 34.5 X 26.5cm. Goog luck!
I read that a couple weeks ago. I’d say it’d be easier to build a box and buy longer rails and swap all the componets over vs trying to make it better. Same amount of time invested either way.
