I haven’t wired my printer up to the replicape yet. I wanted to get the OS ready before adding another variable. On boot, the octoprint service fails to start:
Jan 20 10:47:50 kamikaze octoprint[455]: Traceback (most recent call last):
Jan 20 10:47:50 kamikaze octoprint[455]: File “/usr/bin/octoprint”, line 5, in
Jan 20 10:47:50 kamikaze octoprint[455]: from pkg_resources import load_entry_point
Jan 20 10:47:50 kamikaze octoprint[455]: File “build/bdist.linux-armv7l/egg/pkg_resources/init.py”, line 3130, in
Jan 20 10:47:50 kamikaze octoprint[455]: File “build/bdist.linux-armv7l/egg/pkg_resources/init.py”, line 3116, in _call_aside
Jan 20 10:47:50 kamikaze octoprint[455]: File “build/bdist.linux-armv7l/egg/pkg_resources/init.py”, line 3143, in _initialize_master_working_set
Jan 20 10:47:50 kamikaze octoprint[455]: File “build/bdist.linux-armv7l/egg/pkg_resources/init.py”, line 644, in _build_master
Jan 20 10:47:50 kamikaze octoprint[455]: File “build/bdist.linux-armv7l/egg/pkg_resources/init.py”, line 657, in _build_from_requirements
Jan 20 10:47:50 kamikaze octoprint[455]: File “build/bdist.linux-armv7l/egg/pkg_resources/init.py”, line 830, in resolve
Jan 20 10:47:50 kamikaze octoprint[455]: pkg_resources.DistributionNotFound: The ‘netifaces==0.10’ distribution was not found and is required by OctoPrint
Jan 20 10:47:50 kamikaze systemd[1]: octoprint.service: main process exited, code=exited, status=1/FAILURE
Jan 20 10:47:50 kamikaze systemd[1]: Unit octoprint.service entered failed state.
I verified netifaces is installed:
root@kamikaze:/var/log# pip show netifaces
Metadata-Version: 1.1
Version: 0.10.4
Summary: Portable network interface information.
Home-page: https://bitbucket.org/al45tair/netifaces
Author: Alastair Houghton
Author-email: alastair@alastairs-place.net
License: MIT License
Is this the latest Kamikaze? What date is the image?
That is the version I am using with no to little issues. Some permission issues and a pip module error that only seemed to affect plugins. Did you do a apt-get update / upgrade? I think I tried that once and it broke stuff.
I did several apt upgrades. I didn’t see it mentioned that we couldn’t patch the OS.
Not that we can’t but the image is so new something may be changing with the updates. Try again without doing an OS upgrade. I have two running from the same image. The only thing I have stayed away from us the is upgrade because I saw issues the first time I tried.
Ah, OK, that explains it! Hm… Is there a way to “lock” python packages? Octoprint is pretty particular about the libraries, so an upgrade will most likely break things yes. But we do need to find a way to let people upgrade.
I might change directions and go with a jessie install then install the Thing-Printer binaries. As long as I can get the replicape to init, getting the third party tools running shouldn’t be a problem.
Not knocking Kamikaze, BTW.
I thought kamakazi was the latest Debian Jessie kernel. Maybe I read that wrong.
Sure! Feel free to do that! The big difference is related to getting Toggle to run, so if you do not need that, it might be a good idea. You also need Octoprint and Cura Engine, though.
Does this mean the cape is loaded?
debian@beaglebone:~$ dmesg|grep bone_capemgr
[ 3.913660] bone_capemgr bone_capemgr: Baseboard: ‘A335BNLT,00C0,5214BBBK1111’
[ 3.913690] bone_capemgr bone_capemgr: compatible-baseboard=ti,beaglebone-black - #slots=4
[ 3.955848] bone_capemgr bone_capemgr: slot #0: ‘Replicape 3D printer cape,00B3,Intelligent Agen,BB-BONE-REPLICAP’
[ 4.011206] bone_capemgr bone_capemgr: slot #1: No cape found
[ 4.071286] bone_capemgr bone_capemgr: slot #2: No cape found
[ 4.131175] bone_capemgr bone_capemgr: slot #3: No cape found
[ 4.137266] bone_capemgr bone_capemgr: initialized OK.
[ 5.151340] bone_capemgr bone_capemgr: loader: failed to load slot-0 BB-BONE-REPLICAP:00B3 (prio 0)
[ 18.947436] bone_capemgr bone_capemgr: part_number ‘BB-BONE-REPLICAP’, version ‘0A4A’
[ 18.947476] bone_capemgr bone_capemgr: slot #4: override
[ 18.947495] bone_capemgr bone_capemgr: Using override eeprom data at slot 4
[ 18.947512] bone_capemgr bone_capemgr: slot #4: ‘Override Board Name,0A4A,Override Manuf,BB-BONE-REPLICAP’
[ 19.089518] bone_capemgr bone_capemgr: slot #4: dtbo ‘BB-BONE-REPLICAP-0A4A.dtbo’ loaded; overlay id #0
I tried to fix the prio 0 error by installing device-tree-overlays from the thing repo, followed by enabling the cape in uEnv.txt and running update-initramfs. NoGo.
Which board do you have? It looks like it saw a B3 and an override A4.
I have a B3. I just noticed that override…
debian@beaglebone:/sys/devices/platform/bone_capemgr$ cat slots
0: P----- -1 Replicape 3D printer cape,00B3,Intelligent Agen,BB-BONE-REPLICAP
1: PF---- -1
2: PF---- -1
3: PF---- -1
4: P-O-L- 0 Override Board Name,0A4A,Override Manuf,BB-BONE-REPLICAP
I had the 0A4A listed in /etc/default/capemgr. I changed it to 00B3 and after a reboot got the following:
[ 3.913409] bone_capemgr bone_capemgr: Baseboard: ‘A335BNLT,00C0,5214BBBK1111’
[ 3.913440] bone_capemgr bone_capemgr: compatible-baseboard=ti,beaglebone-black - #slots=4
[ 3.955807] bone_capemgr bone_capemgr: slot #0: ‘Replicape 3D printer cape,00B3,Intelligent Agen,BB-BONE-REPLICAP’
[ 4.011160] bone_capemgr bone_capemgr: slot #1: No cape found
[ 4.071240] bone_capemgr bone_capemgr: slot #2: No cape found
[ 4.131134] bone_capemgr bone_capemgr: slot #3: No cape found
[ 4.137221] bone_capemgr bone_capemgr: initialized OK.
[ 5.151321] bone_capemgr bone_capemgr: loader: failed to load slot-0 BB-BONE-REPLICAP:00B3 (prio 0)
[ 15.737269] bone_capemgr bone_capemgr: part_number ‘BB-BONE-REPLICAP’, version ‘00B3’
[ 15.737303] bone_capemgr bone_capemgr: slot #4: override
[ 15.737322] bone_capemgr bone_capemgr: Using override eeprom data at slot 4
[ 15.737339] bone_capemgr bone_capemgr: slot #4: ‘Override Board Name,00B3,Override Manuf,BB-BONE-REPLICAP’
and…
debian@beaglebone:~$ cat /sys/devices/platform/bone_capemgr/slots
1: PF---- -1
2: PF---- -1
3: PF---- -1
This is mine.
0: P--L 0 Replicape 3D printer cape,00B3,Intelligent Agen,BB-BONE-REPLICAP
1: PF---- -1
2: PF---- -1
3: PF---- -1
debian@kamikaze:/sys/devices/platform/bone_capemgr$
Although we had problems writing the eeprom on my friends board but finally got it written and he showed an override on #4 but it was a B3 on both slots so it didn’t seem to cause a problem as it said the board was already loaded.
3.228549] bone_capemgr bone_capemgr: compatible-baseboard=ti,beaglebone-black - #slots=4
[ 3.267032] bone_capemgr bone_capemgr: slot #0: ‘Replicape 3D printer cape,00B3,Intelligent Agen,BB-BONE-REPLICAP’
[ 3.322517] bone_capemgr bone_capemgr: slot #1: No cape found
[ 3.382478] bone_capemgr bone_capemgr: slot #2: No cape found
[ 3.442478] bone_capemgr bone_capemgr: slot #3: No cape found
[ 3.448413] bone_capemgr bone_capemgr: initialized OK.
[ 3.470839] bone_capemgr bone_capemgr: slot #0: dtbo ‘BB-BONE-REPLICAP-00B3.dtbo’ loaded; overlay id #0
And my uEvn.txt
~ #Docs: Beagleboard:U-boot partitioning layout 2.0 - eLinux.org
uname_r=4.1.6-bone15
##uuid=
dtb=am335x-boneblack-replicape.dtb
cmdline=coherent_pool=1M quiet consoleblank=0 fbcon=rotate:1 init=/lib/systemd/systemd
#In the event of edid real failures, uncomment this next line:
#cmdline=coherent_pool=1M quiet consoleblank=0 fbcon=rotate:1 init=/lib/systemd/systemd video=HDMI-A-1:1024x768@60e
##Example v3.8.x
#cape_disable=capemgr.disable_partno=
#cape_enable=capemgr.enable_partno=
##Example v4.1.x
#cape_disable=bone_capemgr.disable_partno=
#cape_enable=bone_capemgr.enable_partno=
cmdline=coherent_pool=1M quiet init=/lib/systemd/systemd consoleblank=0 fbcon=rotate:1
##enable BBB: eMMC Flasher:
#cmdline=init=/opt/scripts/tools/eMMC/init-eMMC-flasher-v3.sh consoleblank=0 fbcon=rotate:1
uuid=a540a1f5-ca80-4447-b31e-985536fb7cf8
i think the overlay is the problem…
I tried to interpret the Angstrom fix for Debian by installing the only package in the thing printer repo that mentions overlays. Doesn’t look like it worked.
Have you tried the new 01-05-2016 kamikazi image? That is what I am running. It has a few minor issues with a pip module that keeps octoprint from updating plugins.
