Only buy props if they’re cheaper than fans. (I built an air cushion in about 10 minutes with a spare 40mm fan.) You might want to rip the RC guts out of a dead toy. Also, bluetooth isn’t so cheap, so you might want to use one of the other radios. And finally, if you’re trying to save weight, use one of the mini arduinos or a teensy. You don’t need a lot of pin here.
