I just did a test with vector engraving on 19mm thick Merbau hardwood.
I set the piece in position with the focal depth approximately half way through the 19mm. I did this by removing my cutting bed & putting some blocks of scrap wood underneath with some pop rivets nailed in 15mm deep to support the piece. Then I realised I had to find origin point somehow, so I used magnets to hold my MDF guide in place on the bed support rods.
Settings I used were 4mA @ 25mm/s. 0.5mm wide vertical rectangles spaced 0.25mm apart (for the vector engrave). Covered the entire area with the rectangles & then punched out the logo.
Observations
- I’ve noticed since switching to CorelDraw x5 that when I import composite paths from Adobe Illustrator 9 format files, they do some really weird behaviour with lines going everywhere. Totally unusable. So instead of using composite path for the vector rectangles, I just grouped them & imported AI9 & it works perfectly.
- 0.5mm wide vertical rectangles spaced 0.25mm apart seems to be a good size & spacing for this particular material. Vertical lines seems to minimise the vibrations & cause less issues.
- Slightly jagged edges, due to the vector engrave process. Could possibly be remedied by doing a final cut in the logo shape (to smooth those edges).
- Using the vector engrave method is so much quicker than normal engrave. I won’t even bother with normal engrave any more. This took ~9 minutes to complete (91mm x 91mm).
Finishing
- I cleaned up the piece using straight methylated spirits with a nail brush & scrubbed the whole surface area. If you look closely at the pictures you will see there is a slight difference in the black areas once cleaned up.
Overall I’m pretty happy with the results. I did the SHIELD logo, just for you @Dennis_Fuente as I recall you saying you liked SHIELD too on one of my previous tests.
