I just love the Octoprint integration into Cura 2.6. Waited a long time for this and it works so far
Can you do an update or does it have to be a fresh install on the pi?
Same
really enjoying it so far
webcam doesn’t work for me though
@Jonathan_Knirsch Cam is disconnected at the moment but thats the next thing to try.
@Dan_Baldwin Worked with an older Octoprint version. The feature was added on the Cura side.
where can I get the software from
Is there a dvd disc or is download only
Its all online, just look for cura and octoprint.
I looked and could not figure out how to upgrade from curator 15.4 which is what octoprint is still telling you to use, perhaps someone could lead us in the right direction? A link along with instructions?
I’m not talking about slicing form within octoprint. I meant the path when slicing with cura 2.6 beta on PC than sending the gcode to octoprint. Thats a different approach.
@Thomas_Herrmann gotcha that’s a whole other approach I misunderstood that you meant from within octoprint. As far as cura on another pc and using octoprint as a wireless means to send files I didn’t have any luck with 2.5 because it would not save in a .x3g format which is what the Malayan m180 requires so I always reverted back to the 15.6.3 version which seemed to work. That being said I’ll give 2.6 a try! Btw weird that 2.? Is newer than 15.? Don’t you think!
@Dan_Baldwin Cura has been reworked completely thats why the Version number changed afaik.
