I just received my heated bed in the mail for my PB Simple Metal. I ordered some kapton squares with it. I’m wondering. Do I still need glue stick with the kapton?
A guy at work had the same setup and uses glue stick with kapton bit had been using the kapton square that came with his heated bed over a year ago.
I just don’t want to waste the kapton. That stuff is expensive.
After a few prints you use acetone to clean the tape and apply a light coat of hairspray. If you are printing nylon than use glue stick and clean with water.
@Raymond_Blum you may want to grab a Kapton sheet. It is thicker and more durable. I have also seen people express fondness of buildtak. I’ve never used it but it looks interesting. Regardless, I use hairspray on my Kapton and just wipe it clean with rubbing alcohol.
I have had a lot of success with buildtak or equivalent and glue stick. Mostly pla, but worked with abs too. Also on pla, I heat the bed to 55-60 for the first layer and off (10) for all layers after that.
@Keith_Applegarth I second the 3D-EEZ! Works like a charm!!! I applied 3 coats to the glass on my Eustathios Spider V2. Let it try and your good to go. Once your print is done you remove it and starting printing again right away. Good stuff!!!
Long story short. Once you have been printing for a while you learn what you like and what works best for your style. Some really good ideas on here though! I’m sure you will find what best fits for you
