I just registered for the Atmel Tech on Tour in Houston on April 14,
I just registered for the Atmel Tech on Tour in Houston on April 14, 2014. If you are interested, open the link below to see the schedule. (FYI - the event is not free).
http://training.atmel.com/TechOnTour_NorthAmerica
Oooh, I might have to keep an eye out for the napa location. How much does it cost?
(Also, cursing the arduino arm compiler for the due vs. the arm compiler used for the teensy 3.1 - A set of operations (that I need to do 16-32 times/rgb pixel bit ) compiles down to 2 instructions/cycles per operation on the teensy 3/3.1, but 3 instructions/cycles per operation on the due).
The cost is $49 until May 1 when it goes up to $149. Here is the link to what the Tour is going to present. http://training.atmel.com/TechOnTour_NorthAmerica_Houston-Apr14?elq=00000000000000000000000000000000&elqCampaignId=
Unfortunately, nothing in my neck o’ the woods … err … mountains.
There is the option to suggest more stops at the bottom of the first link.
