@Luca_Nervetti I was compiling the 1.93 version which doesn’t reside at the location described in those instructions, so I download the source zip file and manually copied into a local directory then attempted to build it.
when I execute the code that I compile using the instruction i get the following
2017/01/16 18:25:33 main.go:89: Version:1.87
When I look at the version of various files at the location above, they each have different version numbers. so maybe I am compiling correctly but mis interpreting the version number when the code is executed - this is what led me to download the zip file and try to compile locally
@Luca_Nervetti I checked the version report nothing the json widget in chili pepper and it seems like the the version I got was v1.92. I’ll try again. I’m just a bit confused why the zip file version didn’t compile
