I know kind of pointless using two heads to print separate cube… But I was doing some automatic z adjustment between the two towers and it seems to work ok now.
Originally shared by Step Cia
Print log - test print with both head each printing its own calibration cube. There’s some Duet setting issue that I’m ironing out at the moment mainly the z offset between the two towers. It appear my work around is working. Will test some more
https://youtu.be/-xZHdYuHWaw
