I loaded the new Version of Repetier Host ( windows ). While there is print running the Dial indicators where you can move the axis 10mm etc have no number showing up when you move your cursor over the dial. Before I could click on the Z axis and move up 0.01mm while printing.
Haven’t used repetier, but normally I would say manual moves should be disabled during printing. If you need to move the head while printing (why), something is probably wrong with either your printer or slicer /gcode.
That is one of the worst UIs I’ve ever used.
if u have a display, you can do “microstepping z-axis” while printing, its like 0.001mm-stepping with the knob.
I don’t have a display at the moment.So I just wanted to do some testing with my filament and to see if I raise head abit so get my best height. thanks
@Rene_Jurack @Peter_Hertel
