I´m interested in building a really small foot print printer and easy to travel with. Any suggestions?
There are a couple folding designs out there that might suit your needs. Sorry, I don’t have links ATM.
Portabee and FoldaRap are worth looking into.
Thanks,
FoldaRap is one of the designs I´m considering.
Just wondering if there are more printers like those out there.
The GO! line from printrbot (delivered assembled) are theoretically portable although the medium and large versions of the v.2 designs are too big to be considered practical for travel IMHO. I have their GO! v.1 and it is about as big as I’d want to try to lug around (built from a kit but no longer available, love it).
The Portabee GO is super portable also but is not a build-your-own design either. The only build-your-own portable designs I’m aware of are the first two I mentioned.
I thought I saw one design using aluminum extrusions that was foldable. The way it worked reminded me of the Printrbot Simple, with its cantilevered Y/Z axis.
@Simon_Day 's design uses extrusions and looks a bit like the Bukito but I don’t believe it folds.
The Griffin delta printer is carry-on size compatible. This design will probably be my next self built printer. The site: http://www.griffinprinter.org/
I looked for ways to make the Bukito foldable, but never found a way to make the trade-offs acceptable. As it is, you can remove two screws and loosen a third to release the X axis and lay it flat, but given how rigid that joint needs to be, I don’t think that making it any more collapsible than that would be a good idea.
That Partabee Go looks pretty slick!
There’s the tantillus, too, if you’re not stuck on having it fold: http://www.tantillus.org/Home.html
Thanks for all the options!
It really does not need to fold. I just did my version of a 3DR delta (it has the same dimensions) but I would like smoothing tinny to carry around and to show some people a working 3d printer. I will look at the options presented carefully!
@Paulo_Goncalves I think one of the Printrbot Simple models has a handle. I really like my PB-S, and there’s a lot of community support and mods available.
I was going to say the Tantillus and Bukito too. I have carried the Bukito around. It is fairly light and easy to take places, though not as compact as the folders.
I really hope @Daid_Braam gets time to finish his Titan, as it is the best compromise for me!
So much to do, so little time!
Prototype 3 TITAN is not working. Middle one http://daid.eu/~daid/20140528_181853.small.jpg
I tried to save a few bearings, but that causes the whole X/Y to grind to a hold. On the other hand, the Z stage is working fine now. Which was a problem of the Prototype 2. So I think if I put bearings in the Prototype 3 model it should work.
However, it does require a few parts that I do not know how to properly source yet. One is the Z motor of the Ultimaker2 and the other is the electronics of the Ultimaker2.
No idea on the costs, external size is 20x20x22cm for the prototype 4 drawings. Willing to share those if you are up to building it.
(Prototype 3 is 22x22x22, Prototype 2 was 20x20x20, but I ran into all kinds of trouble with the Z stage on prototype 2)
@Jeremie_Francois asked me for the TITAN files, so I uploaded those to:
The latest version is the 200mm version.
@Daid_Braam I just downloaded the TITAN files and it certainly looks good!
I probably won´t go that route has I´m trying to use most of my spare parts and try to source the minimum parts but it looks cool!
I will probably go with a “box” design…lets see if adapt one of the mentioned designs I add one more to the crowd!
@Daid_Braam thanks again for your openess! Also like @Paulo_Goncalves I have lots of spare parts, so I would really like to tweak parts of it (and well, there are UM parts not yet available on the marker, right?). It is modeled with designspark, which I would love to learn… but I will have to postpone this a bit. In the sort time I know only openscad (which the previous version was modeled with). Still would buy one for a quick start if you were to sell kits
I was doing some sketches and playing with a concept in 3D and come up with a footprint of 220x220x330mm(when its not printing - Mendel style printer) with a print area of 140x140x140mm.
I will keep posting info about it - I want to do it in a record time so I can take it to a 3d printer meeting in Lisbon
Lets see if I can make itI
