I made a 3DBendy  in   http://www.thingiverse.com/make:136884 Creative Tools ​
I made a 3DBendy #3DBenchy in #Filaflex
@Creative_Tools
@Steve_Wood_Gyrobot You are a genius in rubber. Was this printed using the recommended speed and layer height? Just for comparison purposes (if that is possible for PLA vs. Filaflex).
Thank you, the print settings are provided in the link above but basically the same as the recommended :
Printed in Filaflex @0.2mm layer height.
220deg C Nozzle temp on glass.
0.4mm Nozzle.
10% Infill.
30mm/s Print speed.
150mm Travel speed.
3mm Retraction @ 40mm/s
Part cooling fan set @ 60%.
Sliced in Craftware.
Printed on a Witbox with Recreus extruder and double drive ‘V’ gear upgrade.
Indeed, a torturous test.
3dbendy
i have some meters of this material, but what is the fisical settings for the extruder? or what is your printer?
