I made a temperature controlled switch for my hotend, but when using M109 to set the temperature, it isn’t activated before the hotend reaches the set temperature. With M104 it triggers the switch when it passes the temperature set for the switch in the config.
The switch is set up like this http://pastebin.com/939FRDxA are there something that should be different, or is the M109 totally blocking anything else from running?
