I must be doing something wrong.  Been printing parts for the reworked i3 and
Been printing parts for the reworked i3 and everything is practically possible to assemble without drilling out. I know many of the instructions say heat things or use a mallet, but it just seems too far off.
I printed a 20mm test cube that measured 20.1 to 20.45 (depending on side). I’m extruding at 95-100% and have measured the diameter of the filament to adjust accordingly.
This is a direct drive housing for an E3D v6, and there’s no way the hot end is going in without heating it or sanding material away.
Any thoughts?
That’s quite a percentage out for such a small test object. I’d print something larger to check with. How about printing two of these, one along the X axis, one along the Y?
The wobbly edges look like over extrusion to me. Check your e steps and measure your filament as accurately as you can.
You might be overextruding a bit. You might be running a bit hot.
Holes being small is a known issue, you’re pulling melted plastic in a small circle and it’s going to contract. Also, “polyhole” problem, a cylindrical hole represented as triangles will be smaller than the original cylinder.
Try printing external perimeters first, then internals. This tends to hold outside dimensions better.
And for opening up holes with a hand tool http://www.thingiverse.com/thing:16956
Also try scaling by a 0.3% shrink factor i.e. 1.003 multiplier.
thx guys, this is all great input. here are a couple things regarding some stuff I’d already played around with…
For @Eclsnowman , I have been playing with upscaling a bit (like 1.03%) and this helps quite a bit, but for items like this that mount to the steppers, the holes are now shifted off center by about half the diameter of the hole (PIA).
@Richard_Mitchell & @Jeff_DeMaagd , regarding the high temps and crappy edges, yes, this wasn’t a good piece cause I was experimenting last night with different settings. I normally print PLA @ 200C but this piece was done at 215. My other parts have crisper edges done at the lower temp. The temp thing has always been confusing cause I normally print as low as I can go but I’ve seen other people swear by printing at 210-215 whereas I sometimes try to get by at 195 even.
The extra perimeters is a good point because it’s set to 3, so I play with that setting.
@Tim_Sills 1.03 would be 3%, that would be way to much I agree.
Also, depending on what slicer you’re using, dimensions can be way off. KISSlicer for me, has completely spot-on dimensions, where Slic3r will constantly undersize holes, etc.
thx @ThantiK , I’ve been using Slic3r so will try another slicer for comparison.
Just a heads up, it also looks like you’re overextruding…a LOT. Follow this excellent guide by @Richard_Horne and get that set correctly: http://richrap.blogspot.com/2012/01/slic3r-is-nicer-part-1-settings-and.html
yeahhh man :wink:
