are you using the original controller board or a replacement? I know with smoothie boards you change the config to home to max and it will show as 0,200. it doesn’t home to bottom left as there is no limit switch there to tell the machine qhen it has reached the end.
Sorry - I should have stated this. I’ve replaced the controller with an Uno and a cnc shield. I’ve got X defined as the “wider” left-to-right axis and Y as the front-to-back axis. All axes and limit switches are working correctly and they follow the “right hand rule” which means I’ve had to reverse the homing direction on X using $3=1 since that switch is at min travel rather than max travel.
When I launch Lightburn and home the machine the position is reported as 0,0 when it should be reporting 0, 210.
Just got this figured out. Needed to reset the machine origin (used Universal GCode sender since command didn’t seem to work from Lightburn console) and proper setting of $10.
