I need a little help. I think one of my drivers has just failed - when I home z, one tower (delta printer) plunges to the bottom, goes back up to the endstop switch at the top and then vibrates for a brief moment. Any z movement sends this tower downward if starting from home position. My fault - I was showing someone how the delta moves with it turned off. My question: can I reconfigure the M5 driver to run the z motor and, how?
This should help you : http://smoothieware.org/3d-printer-guide#toc30
Thanks, Arthur - I thought so but wanted to check before doing it!
And… got it in one. A rarity for me!
What are the specs of the motors on your printer? Recommended motors usually don’t cause problems from manual movement but there are many motors with poor specs which will
I don’t know specifics for certain but it is a standard, Chinese, NEMA 17 running @ 1.5a. I wouldn’t doubt the “poor specs” at all. I’ve replaced many parts on this printer so far. Too many!
What’s the winding resistance, winding inductance and rated voltage?
Well, rated unknown but running @ 12 volts.
