I need help.
I bought a new Powerspec 3d Pro 2 last week. This is not my first printer…I got into 3D printing when the Thingomatic came out and then I built my own MendelMax V2 using the Thingomatic to bootstrap the printed parts.
I have the machine set up to print PLA on the left extruder…and ABS on the right extruder. I am using a SD card to transfer the print code to the machine. (Class 4 SD Card).
I am using Makerware to slide my files.
Here is the problem. Everything has been fine if I do a single material print…but when I do a dual material…in this case a ABS raft and then PLA for the part…the printer will stop for a while between material changes.
In this case it stops, spits out a ton of PLA in one spot, then proceeds to print normally. this creates a large glob of plastic in the middle of the print which is no good.
Other multi prints have a similar issue with the print head stopping between material changes and oozing/melting the plastic under it the nozzles.
Does anyone know how to fix this? Is the machine junk?
I am really not impressed by this machine so far.
Thank you for your help!
