I need help. I have a 40w laser engraver but it moves very slowly on the x axis, only on cutting and only going to the start point. Everything else is ok. Thanks
Yes. It only moves slow when going to the starting point for cutting something. And only on the x axis
make sure you have the correct main board selected in coreldraw settings. The machine will move very slowly if you have the wrong board selected.
Mine does the same. X moves at the cutting speed to the start point. If I spoke Chinese I’d register a software improvement request,
