I need node.key() This module avaitable only in old version firmware build20150127 and older.
I need node.key() This module avaitable only in old version firmware build20150127 and older. How I can do it?
I write this code:
pin = 0
gpio.mode(pin, gpio.INPUT)
pressed = false
started = 0
tmr.alarm(6, 50, 1, function()
if gpio.read(pin) == 0 then
if not pressed then
started = tmr.now()
end
pressed = true
gpio.write(pin, 1)
else
if pressed then
      if tmr.now() - started > 3000000 then
          print("Long press")
      else
          print("Short press")
      end
      pressed = false
  end
end
end)
How I do it this old functions:
node.key(“long”, function()
–[HERE my make code for long or short press button]
end)
or how create new module with this function?
Please help me.
Thanks
~kszere
