I need some basic electrical engineering help with my reactive table project. It has about 750 WS2812 LEDs, which are mostly lit at 25% to 50% brightness, and mostly colors (not white). I’ve got two questions:
First, I’m currently using a 30A 5V power supply, but it might be overkill. And it’s bulky. Could I get away with less?
Second, I’m wondering about the sizing of the wires. Most of the references I’ve found on matching wire thickness to current draw do not mention voltage at all. So, here’s the question: if I’m drawing 30A at 5V from the power supply, do I need a 30A 110VAC power cord running from the wall into the power supply? I have seen cords rated for 30A (for dryers and ovens) – is this really what I need?
Thanks!
