two serial ports are coming up but it doesn’t seem like they are connecting. I’m just confused because I can plug my laptop in and it works just fine doing the same steps. missing/deleted image from Google+
Please try the following link: http://chilipeppr.com/tinyg?v9=true Make sure you are able to connect to the host where the Serial Port JSON Server is running and the Serial port you are connecting to is correct. Try resetting the TinyG and eventually restart the SJPS from Chilipeppr interface. http://chilipeppr.com/
The yellow mark next to your commands in serial console means, cp try to send this commands but don’t get a ack from your GRBl Controlloler. Please try to reset the controller and connect again, also sometimes it helps you reset your SPJS, push the quadratic red arrows button and wait a second …
